How to create circle and other odd shaped holes into the wall?
ReneRumberg
As has been mentioned use 2D splines first, and extrude, Not the Wall tool, though if you can boolean a square out of a wall then you should be able to do a circle, but it is possibly easier this with a 2D Spline....make sure that After creating the first spline for the wall, that you untick create new shape, so that subsequent splines are part of the first spline(or you can 'attach' them later, and you an also boolean splines to create more acurate/complex shapes), they must also be on exactly the same plane, then add the extrude modifier and your wall is done.
