jonnypoland Posted March 31, 2009 Share Posted March 31, 2009 Hi, i am learning mental ray and was wondering if anyone could let me know why this brick bump map is not appearing in my rendered image even when put up to 10 (Max)? Link to comment Share on other sites More sharing options...
WAcky Posted March 31, 2009 Share Posted March 31, 2009 It's very hard to tell whats going on. Are you sure your bump mapping has the correct mapping? Real world or not? Thats really the only suggestion I can make. I find that normal maps dont come up well when in shadows which could be the same with your bump maps here. Any chance you can re-create the issue in a simple scene (eg just a box with the same material applied) so we can try and fix it in max as opposed to trying to guess what the problem could be. Cheers Link to comment Share on other sites More sharing options...
jonnypoland Posted March 31, 2009 Author Share Posted March 31, 2009 thanks i just worked it out from doing that, there was an issue with the scale so the brick was showing, only very small, thanks for your time. Link to comment Share on other sites More sharing options...
