isaac_cm Posted March 31, 2009 Share Posted March 31, 2009 hello, I accidentally set the chamfer segment to 170 now every time I open the chamfer dialog max is hanging up, it seems that this number is stored in the max file, any advice ? thanks Link to comment Share on other sites More sharing options...
vizfx Posted March 31, 2009 Share Posted March 31, 2009 Maybe reset (file menu) Link to comment Share on other sites More sharing options...
isaac_cm Posted March 31, 2009 Author Share Posted March 31, 2009 no it wont work Link to comment Share on other sites More sharing options...
Derek Forreal Posted March 31, 2009 Share Posted March 31, 2009 select the offending object just before you go to lunch. hopefully, by the time you get back Max would have finished its calcs and now you can change (overwrite, don't use sliders) the chamfer value! Link to comment Share on other sites More sharing options...
Tommy L Posted March 31, 2009 Share Posted March 31, 2009 can you turn everything off and then create a box. Maybe it will be able to chamfer 170 on a simple box then you can reset the chamfer value. If not, what happens if you load a new UI preset? Link to comment Share on other sites More sharing options...
isaac_cm Posted March 31, 2009 Author Share Posted March 31, 2009 Tommy L it did not work the value remain derek forreal I hope it did not take longer than lunch , I hear now the CPU fan at 100% speed ! Link to comment Share on other sites More sharing options...
isaac_cm Posted March 31, 2009 Author Share Posted March 31, 2009 thanks guys Max finally finishes calculation, problem solved Link to comment Share on other sites More sharing options...
