Crazy Homeless Guy Posted April 3, 2009 Share Posted April 3, 2009 Travis, I will add all those scripts over the weekend. They are a little off topic because they are not plug-ins nor can you get group discounts since they are free. Do what you want with them, but scripts and plugins should probably be broken out in lists since one is usually about streamlining workflow, and the other is about enhancing or improving your work. Link to comment Share on other sites More sharing options...
danb4026 Posted April 5, 2009 Share Posted April 5, 2009 Can anyone tell me how to access coolpicker once its installed? It is listed as loaded on plugin manager, but I cant find it anywhere. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted April 5, 2009 Share Posted April 5, 2009 Can anyone tell me how to access coolpicker once its installed? It is listed as loaded on plugin manager, but I cant find it anywhere. It is under the preferences, general tab. Simply change the drop down from Default Color Picker to Coolpicker. Then enjoy, the default picker is really to small to be of much use in a field where color is so important. Link to comment Share on other sites More sharing options...
danb4026 Posted April 5, 2009 Share Posted April 5, 2009 Thanks Travis....I have been spending the better part of an hour trying to figure out where the heck it was. Link to comment Share on other sites More sharing options...
Tommy L Posted May 1, 2009 Share Posted May 1, 2009 Anyone know if ProEXR works with Photoshop CS4 Extended? I cant get that thing to work... Link to comment Share on other sites More sharing options...
danb4026 Posted May 2, 2009 Share Posted May 2, 2009 Tommy, what is the purpose of ProEXR? Is it simply to allow you to work on HDRI files and layers within Photoshop? Link to comment Share on other sites More sharing options...
Tommy L Posted May 2, 2009 Share Posted May 2, 2009 Tommy, what is the purpose of ProEXR? Is it simply to allow you to work on HDRI files and layers within Photoshop? Yes. If I open an .erx in PS, it contains just rgb data. ProEXR will bring all the passes on separate layers and recognize the Alpha channel. Link to comment Share on other sites More sharing options...
anvaraziz Posted May 3, 2009 Share Posted May 3, 2009 onion layer manager Link to comment Share on other sites More sharing options...
danb4026 Posted May 3, 2009 Share Posted May 3, 2009 Do you know if onion works with max 2009 64? Link to comment Share on other sites More sharing options...
anvaraziz Posted May 4, 2009 Share Posted May 4, 2009 no idea bout max 2009,, its working perfectly on max2008 64bit. Link to comment Share on other sites More sharing options...
