strange face
isaac_cm
I can not get you FXB into max and I don't have any idea were to start on the 3ds (seriously f-ed up). But I think you problem is an accidental co-planer issue.
Grab those 4 vertices and move them along the dark edge polys, just past the next set of verts on their same edge and that should fix your problem.
could you explain more what is co-planer issue so I dont do that again (newbie here).
please also take a look at that new polygon (max 2009 format) along with a rendered image I keep getting strange faces.
Edited by isaac_cm
coplanar is when you have duplicate polys on top of each other. To find out, select the single poly (not a window or a crossing selection) and delete it. If there's still one there, then it was coplanar.
I got your FBX imported - coplanar isn't the issue but something's very odd.
how did you create this? Box modeling as a start and keep collapsing the edit poly modifiers?
Can you attach the max file instead of 3d or fbx?
Edited by John Dollus
Well, first of all, there are far more qualified poly modelers than me but here is what I would suggest:
1. you could select each offending poly and tesselate so that the warp transitions across more than 1 poly which will smooth it out but that's not really fixing the problem - just increases detail in the model to hide the problem.
2. You could start modeling the piece again. This time, try maintaining a history by adding Edit Poly modifiers when you change the topology though. That way, if it happens again, you can backtrack your steps and correct it without having to redo everything. You can even rename each edit poly step as a reminder of what it does. This will require some practice to get used to as going back and forth in the modifier stack can cause interesting results if you aren't careful. It may seem frustrating but it will make you a better modeler.
When the model is finished, you can collapse the stack down to a single edit poly modifier if you want though it's usually good to keep an editable version as well.
