nodar1978 Posted April 1, 2009 Share Posted April 1, 2009 hello guys, i've got 2 questions about materials, in max + vray thanks in advance 1. i've got glass door, and i have logo which has to be stiked on glass, but logo is bleu text and beckground is white, but i don't need this white color, i need only blue text. is it possible to make something with this? (mask or...?) 2. i've got glass, and transparancy has to be changed from floor till ceiling, so near the floor has to be some kind of white color and near the ceiling has to me totally transparant glass. could you help me in this? thx Link to comment Share on other sites More sharing options...
REDVERTEX Posted April 1, 2009 Share Posted April 1, 2009 1. You can't mask automaticaly the white background. You have to create B/W mask file in photoshop or other raster program 2. Try to use "gradient" for transperancy slot. wish you luck Link to comment Share on other sites More sharing options...
nodar1978 Posted April 1, 2009 Author Share Posted April 1, 2009 thank you for reply could you please tell me what is B/W ? is it in photoshop? i use photoshop as well, so i can do somthing with this. thx 1. You can't mask automaticaly the white background. You have to create B/W mask file in photoshop or other raster program 2. Try to use "gradient" for transperancy slot. wish you luck Link to comment Share on other sites More sharing options...
rmccoy Posted April 2, 2009 Share Posted April 2, 2009 B/W stands for Black and White. In Photoshop: Select the blue part of your image (or white and then inverse the selection). and then fill it with black. Save your image as a new .jpg. This will create the mask that you need. In Max: Place the image you just created in a the opacity slot of a mix texture (I believe this is correct, I do not have max in front of me right now). Put the first material in one slot and your second material in the other. You may need to switch the materials around depending on how the mask image you created works. Link to comment Share on other sites More sharing options...
nodar1978 Posted April 2, 2009 Author Share Posted April 2, 2009 B/W stands for Black and White. In Photoshop: Select the blue part of your image (or white and then inverse the selection). and then fill it with black. Save your image as a new .jpg. This will create the mask that you need. thank you very much I'll try now. Link to comment Share on other sites More sharing options...
nodar1978 Posted April 2, 2009 Author Share Posted April 2, 2009 B/W stands for Black and White. thank you very much it works maybe you know answer for my second question as well? i need to make a glass, with different transperency, so from bottom to top it has to be changed slowly. bottom has to be totally whit (milky) glass, and slowly it has to be changed in to fully transparance glass on top. could you help me in this? thanks Link to comment Share on other sites More sharing options...
rmccoy Posted April 2, 2009 Share Posted April 2, 2009 To get the transition between milky to clear. You can do it two different ways. Put a black to white gradient map in either the refraction map slot. Or put the black to white gradient in the opacity slot. Link to comment Share on other sites More sharing options...
rmccoy Posted April 2, 2009 Share Posted April 2, 2009 If you use a gradient ramp instead of the gradient map you can have more control over the transparency. if you want a simple transition I would stick to the basic gradient map. Link to comment Share on other sites More sharing options...
nodar1978 Posted April 2, 2009 Author Share Posted April 2, 2009 To get the transition between milky to clear. You can do it two different ways. Put a black to white gradient map in either the refraction map slot. Or put the black to white gradient in the opacity slot. many thanks this one works too Link to comment Share on other sites More sharing options...
rmccoy Posted April 2, 2009 Share Posted April 2, 2009 I'm glad I could help Link to comment Share on other sites More sharing options...
