nelpiper Posted April 2, 2009 Share Posted April 2, 2009 Hi guys. I'm using vray displacement and I'm getting this weird artifacts. I turned off the filter from the material because it was causing problems. I tried a lot of settings from the displacement dialog box but I can't get rid of this. Does anyone have any clues? Thanks. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted April 2, 2009 Share Posted April 2, 2009 Are you using a procedural map for your displacement or a bitmap image? If you are using an image it could be because an 8-bit jpeg image does not have a smooth enough gradation in tone causing banding. Try generating your displacement map again but this time do it in 16-bit mode and save as a 16-bit PNG or TIFF file. Link to comment Share on other sites More sharing options...
nelpiper Posted April 3, 2009 Author Share Posted April 3, 2009 I never thought on that. I'll give it a shot and post the results. Thanks a lot. Link to comment Share on other sites More sharing options...
