Brad79 Posted April 2, 2009 Share Posted April 2, 2009 Hi guys, I've just set up a renderfarm using vray DR. I have one master machine and 4 servers all of which are quad core. After running the script 'renderers.current.system_numThreads=4' I have managed to get all the cores working at once. However......when I set vray to render frames of an animation, all the frames appart from the first revert to using only one core per machine. It is as if the max script is turning itself off after the first frame has rendered. If anyone could shed any light on this, that would be great. Thanks, Brad. Link to comment Share on other sites More sharing options...
Tommy L Posted April 2, 2009 Share Posted April 2, 2009 You shouldn't need to run a script to make the Quads use all four cores. They should make like Nike and Just Do It. What versions of max, vray and windows are you running? Link to comment Share on other sites More sharing options...
Brad79 Posted April 2, 2009 Author Share Posted April 2, 2009 Cheers for the quick reply Tommy. Im using Max 9, Vray 1.5RC3, on Windows XP SP2 32bit. When I render without the script, it just uses one bucket for each server. Using the script enables all the buckets (4 for each server) and it renders really fast! When the second frame starts, it stops using the servers and only seems to use the master machine (showing 8 buckets named master). I have checked the task manager of the servers and they are all showing almost 0% usage. Link to comment Share on other sites More sharing options...
Tommy L Posted April 2, 2009 Share Posted April 2, 2009 Check the Affinity in task manager on the local machines. Link to comment Share on other sites More sharing options...
dbibb Posted April 2, 2009 Share Posted April 2, 2009 Why are you still on a Release Candidate? This is fixed with the final release or subsequent service packs of 1.5. Link to comment Share on other sites More sharing options...
