robert taylor Posted April 3, 2009 Share Posted April 3, 2009 Hi All, I am trying to create a particle flow using text that disapears with a gradient ramp, a bit like the words are disolving into sand with wind (space warp) blowing the particles away like dust into an outer space scene (like being sucked into a black hole). This worked on a sphere object just fine but does not seem to want to work on the text i created.I am not sure if me using bevel modifyer and path deform on text has anything to do with my troubles,Does anyone here have any answers,As always any advice is greatly appreciated . Link to comment Share on other sites More sharing options...
anton Posted April 4, 2009 Share Posted April 4, 2009 I am not sure about the setup you have there but you can try putting an editable poly modifier on top of the stack so particle flow sees the text as a mesh? Link to comment Share on other sites More sharing options...
mattclinch Posted April 4, 2009 Share Posted April 4, 2009 Allan McKay has a great tutorial for this. Link to comment Share on other sites More sharing options...
robert taylor Posted April 5, 2009 Author Share Posted April 5, 2009 I am not sure about the setup you have there but you can try putting an editable poly modifier on top of the stack so particle flow sees the text as a mesh? Exellent!!! sounds good,Will try that . Link to comment Share on other sites More sharing options...
robert taylor Posted April 5, 2009 Author Share Posted April 5, 2009 Allan McKay has a great tutorial for this. Many Thank's,Will take a look at that tutorial . Link to comment Share on other sites More sharing options...
rmccoy Posted April 5, 2009 Share Posted April 5, 2009 Allan McKay has a great tutorial for this. http://www.allanmckay.com/tutorials.html Link to comment Share on other sites More sharing options...
robert taylor Posted April 6, 2009 Author Share Posted April 6, 2009 http://www.allanmckay.com/tutorials.html Hi,Many thank's for the heads-up . Link to comment Share on other sites More sharing options...
