janmazan Posted April 5, 2009 Share Posted April 5, 2009 I have created a displacement map for a vertical tile hanging material which works well however gaps are formed at all the corners. How can I get around this? I have seen other people commenting on here saying that using the mesh smooth set to 0 will work however although this closes the corners on my image, I appear to loose quality? Please see image attached. Link to comment Share on other sites More sharing options...
Stalkie Posted April 5, 2009 Share Posted April 5, 2009 I had this problem recently. If you use 3d mapping check ' keep continuity' and that should sort it out. Link to comment Share on other sites More sharing options...
janmazan Posted April 5, 2009 Author Share Posted April 5, 2009 That was simple! thats brilliant thanks for your help. Link to comment Share on other sites More sharing options...
REDVERTEX Posted April 6, 2009 Share Posted April 6, 2009 also keep in mind the SHIFT option. Link to comment Share on other sites More sharing options...
Stalkie Posted April 6, 2009 Share Posted April 6, 2009 That's new to me - what is the shift option? H Link to comment Share on other sites More sharing options...
markf Posted April 6, 2009 Share Posted April 6, 2009 I have had the same problem. Often I need to use 2D mapping for displacement. My understanding is that 3D mapping is used with procedural maps and 2D mapping is used with bitmap maps. I tried using 3D mapping with a 2D bitmap and it caused crash. My solution is to invert the 2D map and use negative displacement. I also am curios about the Shift option. I have not heard of this Link to comment Share on other sites More sharing options...
