Stan Zaslavsky Posted April 6, 2009 Share Posted April 6, 2009 Hi, So far my exterior walls are looking a bit plain and the two types that i've used before - one A&D material with a bitmap in the diffuse and the other using Promaterials Wall Paint - both have issues. I prefer to use A&D because then i can add bump and other effects - ProMat Wall Paint is a bit limited in this flexibility and also can only take RGB values for the paint rather than a bitmap. What are some ideas and tips for creating a more realistic exterior wall paint material? - someone was talking about adding a mix material in the bump slot and mixing two colours together? does this make sense? thanks in advance for your help Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 6, 2009 Share Posted April 6, 2009 I like using a fall-off map set to fresnel and two variations of the colour. subtle but adds nice variation. Also a tiny bit of glossy reflectioons help. Set it to FG and highlights only to save on render time. Reflection of 0.3 and glossies of 0.2 work well. A tiny noise map in the bump slot and a large AO radius add that extra bit of detail. jhv Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted April 6, 2009 Author Share Posted April 6, 2009 I like using a fall-off map set to fresnel and two variations of the colour. subtle but adds nice variation. Also a tiny bit of glossy reflectioons help. Set it to FG and highlights only to save on render time. Reflection of 0.3 and glossies of 0.2 work well. A tiny noise map in the bump slot and a large AO radius add that extra bit of detail. jhv thanks Justin - i'll try this out. Link to comment Share on other sites More sharing options...
