Mr Max Posted April 6, 2009 Share Posted April 6, 2009 Hey guys, I need your help on this situation and I know that most of you are well experienced with it! _I'm trying to construct an interior spiral staircase with a spiral void next to it. on one side of the void walls, I need to simulate water that is falling down along the wall to the lower floor where it goes into the ground floor. I'm still a bigginer in 3d max and I don't know how to make the waterfall along the wall! any help would be great! I know how to make a standard water material in vray but how can I simulate it while running down the wall? (still image not an animation!) _ My second question is : the staris, railings, landing, hallway are all in glass(frosty,milky & clear) and I don't know what is the proper way to light it up! it's already getting burntout with default lighting and is toooooo bright! would you suggest any type of hdri's for the scene or just using vray lights to light it up! no windows around or doors! Thanks for you help in advance! Link to comment Share on other sites More sharing options...
Mr Max Posted April 6, 2009 Author Share Posted April 6, 2009 any help would be really great please Link to comment Share on other sites More sharing options...
luckymutt Posted April 6, 2009 Share Posted April 6, 2009 Holy cow, man...give a little more than an hour before you bump your thread... In regards to your first question, if it is only a still, then you would be much better off just adding it in Photoshop. It would be faster and prolly look better. Link to comment Share on other sites More sharing options...
BrianKitts Posted April 7, 2009 Share Posted April 7, 2009 animated texture map in the opacity channel, or if your map is tileable you can animate the UVW placement of the map on an object to simulate your falling water. Link to comment Share on other sites More sharing options...
Mr Max Posted April 7, 2009 Author Share Posted April 7, 2009 Holy cow, man...give a little more than an hour before you bump your thread... In regards to your first question, if it is only a still, then you would be much better off just adding it in Photoshop. It would be faster and prolly look better. thnks for the help man:) I'm not sure if it would work in photoshop with all the reflections and glasses in the scene. I found a nice tutorial about making water falls with Parray and using a simple noise map for dropping water along the wall. i'll try different things i guess thanks for stopping by Link to comment Share on other sites More sharing options...
Mr Max Posted April 7, 2009 Author Share Posted April 7, 2009 animated texture map in the opacity channel, or if your map is tileable you can animate the UVW placement of the map on an object to simulate your falling water. hey brian. thanks for the advice but i'm not too proffesional yet with max and I have no clue about an snimated texture map nor animating uvw map. if it's not so hard to do, i'd really really appreciate it if you can make such a map for me on a simple wall and show me how it looks like(hope i'm not asking for too much:o) thanks for all the help buddy Link to comment Share on other sites More sharing options...
Virgil Johnson Posted April 7, 2009 Share Posted April 7, 2009 Evermotion has a couple of tutorials that might help. One is a fountain and one is water dripping. Virgil Link to comment Share on other sites More sharing options...
Virgil Johnson Posted April 7, 2009 Share Posted April 7, 2009 just remembered 3D Allusions has also a waterfall tutorial that is pretty good. Virgil Link to comment Share on other sites More sharing options...
Mr Max Posted April 7, 2009 Author Share Posted April 7, 2009 thanks a lot virgil I did found great tutorials at cgtutorials.com and they had beautiful waterfall effect, but since it's an indoor and streaming down the wall i need something more peacefull to go with the link that "Libertycityanimation" gave me cos that's the effect i'm looking for thanks for all the help guys Link to comment Share on other sites More sharing options...
kippu Posted April 7, 2009 Share Posted April 7, 2009 vizdepot had a waterfall tutorial in there somewhere Link to comment Share on other sites More sharing options...
