YOHKOH Posted April 6, 2009 Share Posted April 6, 2009 Hi Y'all Is there a way to centre a shape to a splime prior to lofting it. Its very frustrating trying to loft a set of kerbs and the loft is generated all over the place, mirrored or flipped in its axis. I've found it also depends on how I generate the original shape, ie if I start the shape and work clockwise the loft is generated one way and then another way if i start counterclockwise. Many thanks Link to comment Share on other sites More sharing options...
WAcky Posted April 6, 2009 Share Posted April 6, 2009 I think its relative to the said items' pivot isn't it? Either try moving the pivot or use a sweep instead... Link to comment Share on other sites More sharing options...
amer abidi Posted April 6, 2009 Share Posted April 6, 2009 Pick the path THEN shape, and it should be centred (assuming the shape's pivot is centred ofcourse) Also as Wacky said, the sweep modifier is less of a hastle in some situations. Link to comment Share on other sites More sharing options...
