isaac_cm Posted April 10, 2009 Share Posted April 10, 2009 hello, I was modeling a walls with the wall tool and I placed windows then I found new edge generated automatically !! any idea why it generate that edge ?? pic attached Link to comment Share on other sites More sharing options...
SandmanNinja Posted April 10, 2009 Share Posted April 10, 2009 That LOOKS like the edge that gets created when you convert a spline into an editable poly. Link to comment Share on other sites More sharing options...
isaac_cm Posted April 10, 2009 Author Share Posted April 10, 2009 but I did not convert it yet !! is it something max 2009 do automatically ? thanks for repely Link to comment Share on other sites More sharing options...
isaac_cm Posted April 11, 2009 Author Share Posted April 11, 2009 Thanks but the no open vertices and of course I need edgeface view on however it is not important thing I just wondering why it act like that Link to comment Share on other sites More sharing options...
isaac_cm Posted April 11, 2009 Author Share Posted April 11, 2009 When I used AEC there was no edges it appear suddenly when I start place windows (as you see in the picture) on a wall without any window !! I see that odd since there is no object on that wall for max to generate that edge. Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted April 11, 2009 Share Posted April 11, 2009 (edited) sorry double post Edited April 11, 2009 by Gus_Rayvus double post Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted April 11, 2009 Share Posted April 11, 2009 The edge on right has always been there. Once you placed the window in it, it regenerated the mesh and made the edge visible. To demonstrate this take your mesh before you place the window in it, put an edit mesh modifier on it. Click edges, select all and click make visible. You will see that the edge layout, especially with windows in it, is very messy. As you need to do more complicated things with the walls (displacement, unwrapping) you might find it better to box model these walls so you have more control over edge flow and will be able to make future edits faster. Obviously that might not be necessary for what you are doing. Link to comment Share on other sites More sharing options...
isaac_cm Posted April 12, 2009 Author Share Posted April 12, 2009 Libertycityanimation when I add stl check I got no errors but it add another edge to the window !! but I now convert all walls to editable poly. Gus_Rayvus Thanks alot that explain alot , Appreciate your reply Wonderful community Link to comment Share on other sites More sharing options...
