AutoCAD 2004 - Copy BASE and PASTECLIP problems
SandmanNinja
Hello,
I am using AutoCAD 2004 and have a very rudimentary knowledge of it.
Usually just enough to get me into trouble. :)
I normally just use it to trace out very basic walls for a very rough floorplan to compliment my photography of a house (I measure the house with a sonic measuring device). So I don't go much beyond using basic polylines and moving/copying/offsetting/etc.
However, I am trying to incorporate AutoCAD into my 3DS workflow and have come across a weird problem.
I open an existing drawing and type UNITS to get the units.
I then select the bits that I want to bring into 3ds, then do a Copy with Basepoint, then create a new AutoCAD file, type UNITS and set them to be the same as the original file, then type PASTECLIP and specify my base (generally 0,0).
When I zoomed in on some of the arcs and what-not, they are NOT arcs, but rather corner verts.
Obviously I'm doing something wrong, but I did try to cover the bases with checking the units types of the original and (trying) to make the new sheet the same.
Any ideas what I might be missing?
