Vray Sun
covono
Hi guys, Thanks for helping.
Is it possible to set the Vray sun in a wide angle (almost parallel to the ground) without having the red sunset light color? If so where how can I control the Sun's color?
Thanks again
You can read more about the white balance here under Example 8: http://www.spot3d.com/vray/help/150SP1/examples_vrayphysicalcamera.htm
The Vray sun+sky systems are physically based, ie the colour and intensity of the direct and ambient light is dependent on the sun's postition in the sky. All exposure and colour control is then supposed to be done in the camera settings, just as you would do in real life. If you want more control over the lighting then you can use a Vray sphere light or target direct light in conjuction with either an HDRI or the GI environment override rollout of the render settings.
