How do I draw at specific elevations?
Michael J. Brown
In AutoCAD there is a way to set the active elevation so that all objects drawn or modified get done so at a user-defined elevation/height (i.e., 10' A.F.F., etc.)
Is this doable in MAX? I could always just model everything for my second floor, then move it all up. But it'd be much simpler drawing directly on that upper level automatically.
Thanks.
i don't think you can do that but a possible workaround would be to create a plane, put it at the correct elevation and then build on the plane using autogrid.
edit: actually, you can create a custom grid and put that at the right elevation and then build on that... should be a better solution
