max 2009 file shutting down after every 5 minutes
chow choppe
hi
everyone
i am working ona file which has a lot of polygons
now whats happening is when i do some work ON IT IN ONE VIEW IT WORKS FINE
AS SOON AS I TRY TO ORBIT IT OR ARC ROTATE IT
the file shuts down and saves the file in autobak folder.
this is happening every 5 minutes.
i am not able to figure out if there is any object with that error in it
i also used optimize tool but it still gives me error
i also tried using open GL but it still shuts down abruptly
Can anyone suggest how i can i correct this
Thanks
i have HD4670 512mb card
8Gb ram
q6600 and abit Ip 35 e
When Max is acting bad deleting the 3dsmax.ini file is always a good place to start.
As far as troubleshooting... If the file is layered, turn on 3 layers at a time, and only rotate with those layers on. If there is corrupt geometry, this will allow you to start to isolate the layer, which will make it easier in locating hte bad objects.
I could load the file fine and was able to move the scene around - pan, zoom,rotate, etc.
Whatever the problem was, I think the file itself is fine.
Nice looking model.
There are 180,000 polys - maybe it's your hardware?
Here is an AO render of the scene.
Rendered on:
Max 2009 Design
Q6600 Quad-Core
8-gigs ram
WinXP64
nVidia 8800GT w/1-gig ram
Could it be the view cube problem?
I had a file with a lot of polys and it crashed continuously every time I tried to pan/zoom/rotate. There have been several threads about it and how to turn it off, it might be worth a try...
