YOHKOH Posted April 15, 2009 Share Posted April 15, 2009 Hi Does anyone know a way to chamfer the edge of a box but vary the radius of the chanfer from 0 to say 30mm. The block is also curved. Any help would be appreciated. I'm trying the loft tool but with not a lot of success in this instance. The porblem is how to centralise the loft. Ta Link to comment Share on other sites More sharing options...
MrCAD Posted April 15, 2009 Share Posted April 15, 2009 Well what I would do is.. 1. Draw a rectangle (Spline) 2. Extrude it (use the height you need) 3. Convert to editable poly 4. Select the edges you need to chamfer within editable poly and select the Chamfer option hope it helps cheers Meher Link to comment Share on other sites More sharing options...
SandmanNinja Posted April 15, 2009 Share Posted April 15, 2009 You can also set the edges of some Mental Ray A&D or ProMaterials (probably the latter) to fillet/chamfer. Link to comment Share on other sites More sharing options...
YOHKOH Posted April 15, 2009 Author Share Posted April 15, 2009 Sorry I didn't explain myself clearly. I need to vary the fillet along the edge of the block so that the edge tapers down from a fillet radius of 30mm to 0mm. Anyways, we have done it in Rhino but would like to know if its possilbe in max. Link to comment Share on other sites More sharing options...
