pyang Posted April 21, 2009 Share Posted April 21, 2009 A & d material is 2 sided, how do you have a different material on the back side? or is there no option? Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 21, 2009 Share Posted April 21, 2009 yes use a TOP/BOTTOM shader with the two different A&D shaders in each slot. Make sure that Backface cull if OFF for eash A&D and the co-ordinates are set to local jhv Link to comment Share on other sites More sharing options...
pyang Posted April 22, 2009 Author Share Posted April 22, 2009 thanks Justin Hunt said: yes use a TOP/BOTTOM shader with the two different A&D shaders in each slot. Make sure that Backface cull if OFF for eash A&D and the co-ordinates are set to local jhv Link to comment Share on other sites More sharing options...
