Stan Zaslavsky Posted April 21, 2009 Share Posted April 21, 2009 hi there, is there any way to set up a default setting of the steering wheel (which i'm finding quite useful) to be always set to mini-object view wheel? its a bit of a pain to always have it reset to the original large wheel and then have to change the settings? thanks in advance Link to comment Share on other sites More sharing options...
rmccoy Posted April 22, 2009 Share Posted April 22, 2009 I don't use this feature. But if you go to your menu bar and choose: Views->SteeringWheels->Properties: Once in there you have the option to set the size. I would guess that this would change the size and also save it in your 3dsmax.ini file. If that doesn't work: Once you have set everything up. You could try and save your custom UI by going to the file menu and choosing: Customize->Save Custom UI Scheme. If that still doesn't work: I would assign a hotkey to it. go: Customize->Customize User Interface->Keyboard... In the drop down menu "Group" choose SteeringWheels, Then assign the a hotkey to the appropriate one. Hope this helps. Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted April 22, 2009 Author Share Posted April 22, 2009 thanks Ross - the last suggestion was great. cheers, Link to comment Share on other sites More sharing options...
