overclocking..
What motherboard, ram, cooling and power supply are you using?
hey thanx for helping mate,i am using-
intel dg35 mother board.
8 gb ram ddr2,
air cool,
and for power supply i have work horse cabinet from i ball,
(International designer series
5.25 Inch Bays: 2 External bays
3.5 Inch Bays: 1 External bay, 5 Internal bays
1.44MB Floppy Drive Bay: 1 Floppy drive bay
Carry Handle: Unique design with carry handle
Motherboard Form Factors: Standard ATX & Micro-ATX motherboards
Front USB Ports: 2 Front USB Ports
Front Audio Ports: 1 Audio-out Jack + 1 Mic-in jack
Cooling Fans: Bundled with 1 x 9cm cooling fan
Extra Cooling Fan Provision: Provision for 1 more extra cooling fan
Heat Vent: Heat-vent chimney technology for better air flow
Power Supply: 400 Watts 24-pin power supply
Available Colours: Full Black & Full Silver
Dimensions: 18.9 x 7 x 18.7 inches (H x W x L)
with stock supply.i am totaly blank on to it,i u want i can help u know more specs.
Yeah, second what Maria said - that MB won't allow much control over CPU and RAM speeds, and 400W power supply isn't going to cut it with or without a designer carry handle. If that's a small form factor case you're also likely to have cooling issues.
with 400 watts and an intel motherboard , i would suggest you forget about it and also advice to read a lot more on overclocking from a hardware specific forum , before thinking about it
hey thanx mate.ill go through it.would love more info and others to say some thing,n yes
good to see you here and i would love to know u better,if u dont mind?,we can chat n get to know each other better.
As the other 2 stated, that system is not going to be a easily overclocking set-up. You really need to get a better motherboard for starters.
thanx for the reply budy,but in some other forum i saw ,some did overclocked the same configuration at 3.2 gh. will get some info over it as well.
Well, we're not saying you can't, we're saying we wouldn't. And we're probably smarter than that other guy.
yes buddy you are right,but i think atleast by this threat people should know what the minimum configuration,we should at least have to overclock.
it can be a gr8 source of info foe us as well as for others.
