Msamir Posted April 22, 2009 Share Posted April 22, 2009 I've been working a file for about a week now and today suddenly when I was trying to merge some objects from that file to another one I got this error then another window turned about saying File Open Failed and then the path of the file, any idea whats going on or how can i recover that file ? Thanks in advance Link to comment Share on other sites More sharing options...
Camby1298 Posted April 22, 2009 Share Posted April 22, 2009 In the past Ive had this probelm come up as well when working along with companies in China. The files I received from China were named in Manderain so I had to rename them and the textures files and move them to a folder that wasnt named in Manderain either. So Im not sure about your files but and I found that if I moved the file to a location that can be pathed it opened just fine. Hope that works. Link to comment Share on other sites More sharing options...
Msamir Posted April 23, 2009 Author Share Posted April 23, 2009 Didnt work, I tried to merge the objects from the file to a new one but that didnt work either, gave me the same error, the strange thing is that the file size is still the same before it made that error ! Link to comment Share on other sites More sharing options...
Bugga_Guy Posted April 23, 2009 Share Posted April 23, 2009 Has the file been been saved in a newer version of max and then tried to merge/open in a older version? Can you recoever your work from your autosaved files? Link to comment Share on other sites More sharing options...
anvaraziz Posted April 23, 2009 Share Posted April 23, 2009 move the file to another location like desktop n give a try,,, Link to comment Share on other sites More sharing options...
Msamir Posted April 23, 2009 Author Share Posted April 23, 2009 Has the file been been saved in a newer version of max and then tried to merge/open in a older version? Can you recoever your work from your autosaved files? No, We're using Max 9 at work we dont have any newer version, the file just decided not to work when I tried to open it ! I'll try the autosaved files. @Anvar: I tried copying the file to another location and still didnt work. Link to comment Share on other sites More sharing options...
