max6 and file linking
colorID
hello every one, i ve been using viz 4 for almost year and half and i m really happy of the new max 6 realse.
i had a wonder about the file link manager? does max 6 support it..as i do most of my modeling at autocad.
if it is not there,is there anything that substitute ?
thnx alot :)
  • 2 weeks later...
  • 2 weeks later...
On the VIZ4 newsgroup at news.autodesk.com there has been a long talk about it.
Basically, transferring the "file link" to max6 caused a few problems (since max does a lot more then VIZ and they had to be sure that the tool supported those features.
The quick solution was releasing the link-tool without possibility of updating.
That said, they asked for feedback about the tool and it's implementation and I said that they should consider merging the XRef-feature and the file-link manager and support all supported file formats if possible. That way you would be able to link (and update) *.max, *.dwg but also *.3ds and others. Now that would be very usefull since I use ArchiCAD, which can export DWG-files, but the export through 3ds files supports the texture mapping and that makes for a huge timesaver in max.
