Vray for Sketchup
Hi All,
I would appreciate if anyone can assist me on this matter;
I have been using vray for sketchup but i have some problem:
1- How can i increase the resolution of final render image, i know that i can change the image size but it does not change the resolution ( i am looking for a fairy good resolution with crispy look)
2- how can i render lines in vray or do a wireframe render with vray:confused:
Thanks,
Thanks but:
1- I am looking for to increase the resolution in vray however i can make the size of image bigger but it does not improve the quality
2- WF in SU is ok for A4 size image not for A1 size,
I wonder if there is a way to render line with vray?
Cheers:confused:
  • 2 weeks later...
Image resolution is adjusted in the "Render Options" menu under "Output"
- If you have the toolbar open, its the yellow-ish tag with the "O" on it.
- Otherwise, Plugins > V-Ray for Sketchup > Options > Output
From there you can adjust the aspect ration, resolution, etc.
  • 10 months later...
is there a way to increase the DPI besides going to photoshop? the default dpi from Vray is 72. if i wanted a to create an image that is 5000x2500 pixels, i know how to change that, but i want the dpi to be 150 or 300 or more. is there a way i can change that? thanks in advance.
V-Ray for Sketch-Up visualisation professionals a high-tech solution producing high-quality images of unmatched realism.
Sketchup animation has improved with the V-Ray plugin support. V-Ray is a rendering plug-in that enables Sketch-Up users to have a performance enhancements for producing an outstanding image quality.
Manoj Singh
