Need help -"understanding elevation plan"
illusionist
hi guys, i'm new here. Its a dumb question but actually i was never into architecture before, i m just a simple 3dsmax guy , but recently i got an elevation plan from which i had to model a building.. but it seems i m having problem understanding symbols ..heres a pic stating symbols:
1.ok so what exactly :confused: is this box with cross..i dont know also why two colors(red in 1. and green in 2.)
2.and what do the 3 and 4 mean..im sure 3 is not stare case, is it a curved surface
please suggest some book or links to get hold of these symbol stuff, i need help very urgently..
any suggestion would be very helpful
thanx
It's hard to tell without seeing more of the drawing but usually a cross like that denotes a void or double height volume.
3 seems to be an arch or something but it's hard to say without another drawing to cross reference it. 4 I would guess at a chimney of sorts. Like I said without knowing the project or seeing the full drawings it's just guesswork on my part. Hope that helps.
Edited by stef.thomas
http://www.amazon.com/Architectural-Graphics-Francis-D-Ching/dp/0471209066/ref=sr_1_4?ie=UTF8&s=books&qid=1240503407&sr=1-4
Ching's books are good for beginners to get a sense of the different symbols
Though what you show is rather context sensitive. #4 usually refers to a void such as an shaft or space between walls for pipes or ductwork. For #2, that could be open to below or also could be an indication of sloped surfaces for a small terrace/roof drain. #1 is interesting - could be a piece of large equipment in the room? #3 usually indicates a curved surface - an arch in this case.
ok guys heres the plan
Sorry, I didn't notice that feature was on the outside. It looks like there is an elemnet there, but it is hard to tell what it is. It does not look like it is weel represented on the plan, and it looks as though it might be drawn wrong.
In a situation like this you need to request more information from the architect. The most effective way is to deal with a detail like this is to ask for a section through it in both directions, as well as any other details that they can provide you.
