davidarcila Posted April 27, 2009 Share Posted April 27, 2009 Hello, i have this scene im making in 3dsmax that i want to post produce in After Effects, that's why i want to render each layer separately, rocks, plane and background. When Rendering the plane, Vray only renders the plane, but not the reflections of the rocks that fall in the plane. I'm using the layer manager for selecting the things i want to render and Vray as the render engine. Thank You very much, any help is appreciated. Link to comment Share on other sites More sharing options...
kippu Posted April 27, 2009 Share Posted April 27, 2009 what about rendering vray reflection in the render elements ...would that work? Link to comment Share on other sites More sharing options...
davidarcila Posted April 29, 2009 Author Share Posted April 29, 2009 mmm...I tried using render elements but i get the same result, a plane with no reflections. But i think it's using the render elements just as you said. Link to comment Share on other sites More sharing options...
Setiawan She Posted May 3, 2009 Share Posted May 3, 2009 Try to right click on the object you don't want to render, and then uncheck "visible in camera", I hope this way could works Link to comment Share on other sites More sharing options...
Setiawan She Posted May 3, 2009 Share Posted May 3, 2009 I mean, right click on object you don't want to render, choose properties, and the uncheck "visible in camera" option in object properties dialog, good luck Link to comment Share on other sites More sharing options...
