A question about white interiors?
innerdream
Thanks. Any tutorials for Photoshop on this that you know of?
ctrl+u should get you started... you can desaturate and control the hues.. you can select the walls by colors or by masking them.
If you need some help... send me a pm with a picture of the rendering
Thanks for the info I'll check it out. Isn't there a simple way to set white balance across the entire image?
Robert,
I think you are best addressing the root problem in the render engine. Color correction is pretty simple in post, but in the long run its prob best to get a workflow going that enables just some levels balancing in post rather than color adjustments.
Robert,
Thanks, that is what I suspected.
Simpler than that???:eek: ... well, you can hire me! that would be a one click solution :D
Edited by 1eo
in mental ray photographic exposure you set your whitebalance. works the same way you'd do it using a real camera. this is a far better method than changing the whitebalance in post.
I've been using Modo and I just set the walls or whatever to 100% white and then set my lighting to RGB values that match real world lights and sun. I get mixed results.
you'll need to do it in post then. using either photoshop or lightroom. best to render to 16-bit float so you can do this more precisely.
a quick and cheap solution (not advised) is to use photo filter to push your colours cooler/warmer until something that is in direct light and is white looks white, and everything else falls off with appropriate colours.
Okay, thanks.
