extrude problem
isaac_cm
hello,
I was modeling a chair and I tried to model the back legs and begin extrude faces by selecting the first editable poly in the stack - I have the stack like this : edit poly , tubosmooth, edit poly , tubosmooth (see pic)
but the problem when I select the last turbosmooth in the stack the model get missed up (see pic)
any advice ?
thanks
no its not a defect. its because your 2nd modifier is dependent on the edit modifier below it. for example, if you extrude a face in the 2nd edit poly, then go back to the 1st edit poly, and delete that face, how would the 2nd edit poly extrude that face?
ok, this is a very simple way of explaining it, and its more complicated than that, but it's a logical way of working.
