Tiling with UVW?
mzagorski
Hey guys,
OK... still working on my grass texture. Ive got a few seperated areas of grass in my landscaping so Ive attached them to each other and applied a UVW modifier to the whole lot.
How do you guys get your texture for grass to tile nicely?... Do you get the size of the UVW map and work it out from that? .. so if its 12' x 10'-6" you would tile 1.2 x 10.6?
Thanks
try making your texture in photoshop or in some other photo editing software and then FIT it in your mesh.
The good thing about doing the whole map in a photo editor is that you can break away from the monotony of the tile effect when mapping materials onto a surface of geometry. my two cents worth IMHO
  • 1 month later...
I'm not entirely clear on just what you're asking.... but there are a couple ways to change how a map tiles. If you want to make sure the aspect ratio is the same as the source bitmap, use the Fit to Bitmap button and pick the bitmap file. Otherwise... remember you can always type in a size for the UVW map gizmo yourself. I like to go by a default 10'x10' or 20'x20' for things like ground, decking, and roof tiles so I can swap around pre-made materials pretty easy, whereas if I let the gizmo fit the object instead, I'd have to tweak all day to get anything consistent.
Another cool technique for things like grass dirt and stucco is to use a blend material. Use the same texture in both slots but rotate the bitmap in one of the diffuse channels. Viola a non tiling texture. :winkgrin:
[ March 08, 2003, 02:26 PM: Message edited by: Sawyer ]
