Onzki Posted April 29, 2009 Share Posted April 29, 2009 (edited) Hi, (just for those who don't know yet), I just wanna share an alternative solution for ARX error message / eduplicate key / notkind of this class stuff.. that i encountered when i received a downgraded autocad file, and executes a paste as block command.. internet search points you to install hotfixes provided by autodesk, However- in case if it doesn't work-like what i've encountered..here's a simple alternative solution: when the error msg. appears- just press the ''ENTER" key for about 10 seconds until the error message got tired on you and the block will command will resume... and your on your way. quite irritating, but if you're in a rush- and you can't tweak anything in your admin-restricted pc.. well you can live with it for the meantime error msg looks like this: http://picasaweb.google.com/arkionzki/AUTOCAD?feat=directlink#5330038849125683330 Edited April 29, 2009 by Onzki update Link to comment Share on other sites More sharing options...
