How do I delete extra faces?
Michael J. Brown
I know this is (has to be) a simple issue to rectify. But I'm learning on the fly a bit here. How can I either avoid the occurance of these left-over faces after having applying a negative extrusion on a face, or delete the left over face 'flaps' without taking out other needed faces?
To get to this point I did an Extrude in the Polygon mode of the Edit Poly modifier. The Extrusion Type was Local Normal.
Thanks Dean. It just seems that there'd be an easier way than this. It's easy enough to perform for the type of object I have here. But when you get into needing to do multiple negative extrusions on the same object, the process you suggest can get to be a bit cumbersome.
