rogue3d Posted May 1, 2009 Share Posted May 1, 2009 so i've spent 20 minutes checking my settings and can't figure this out. my cursor is ALWAYS an arrow from windows. The gizmo will change depending on if I'm in move, rotate, scale, but the cursor icon used to change as well to let you know what mode you were in. Any idea how to fix this? it looks like it's stuck on the "select object" mode. even though move is highlighted on the toolbar....weird. Link to comment Share on other sites More sharing options...
isaac_cm Posted May 4, 2009 Share Posted May 4, 2009 try press q select object then press w, e or r as you want Link to comment Share on other sites More sharing options...
