Tim Saunders Posted May 1, 2009 Share Posted May 1, 2009 I am wondering if anyone knows of a way in Premier to do something like the following. I have a rendered still. I want to render a region of the same space with animated things happening. I could easily render that region and composite that on top of the previously rendered still, but I am wondering if I can create a mask with blurred edges to make the region blend in with the still. Due to unlike GI solutions, you can see an edge around the rendered region. I hoped I could just make a shape in Photoshop with blurred edges, of the region I want masked. But I'm not sure how to apply the mask to the frames in Premier. Any help would be great. Link to comment Share on other sites More sharing options...
vizfx Posted May 4, 2009 Share Posted May 4, 2009 I think rendering in mov file format with transparency (alpha channel) for the composite channel is the easiest choice Link to comment Share on other sites More sharing options...
Stephen Thomas Posted May 4, 2009 Share Posted May 4, 2009 After Effects is the program for that. You can draw a shape for your mask then feather it to blend your footage. Then render out a new frame sequence or avi to bring into premiere. Link to comment Share on other sites More sharing options...
