huntch3 Posted May 8, 2009 Share Posted May 8, 2009 Hi everyone Here is a pic of my project....the problem is when i render this in vray, this curved geometry gives off this strange blotchy shadows...I checked the geometry and i dont think theres anything wrong with it....and there is nothing below or on top of it to give a strange reflection....what do you think is the problem?any suggestions? thanks Link to comment Share on other sites More sharing options...
rmccoy Posted May 8, 2009 Share Posted May 8, 2009 do you have coplanar faces? Link to comment Share on other sites More sharing options...
huntch3 Posted May 8, 2009 Author Share Posted May 8, 2009 (edited) sorry what are coplanar faces? the way i created this geometry was that i made a single line, arrayed many times with a slight angle degree change each sequential array, then i u-lofted each line to create the whole surface..after, i shelled it...not sure if that helps answer your question...but let me know Edited May 8, 2009 by huntch3 Link to comment Share on other sites More sharing options...
rmccoy Posted May 9, 2009 Share Posted May 9, 2009 coplanar faces are when you have two planes (quads/triangles) that occupy the exact same space. a lot of times they will produce weird results like what you have. Not sure if this is the problem. but you may want to double check Link to comment Share on other sites More sharing options...
