Rendering on a 32bit sytem
Hi guys! I'm in doubt in the case that my unit having a 4gb of RAM could'nt maximize the RAM usage in rendering large scenes. It's limiting the RAM only at around 2.5gb. Beyond that it crashes. When I am checking the run in the task manager, there is still available RAM but when it reaches for that 2.5gb & go above that it crashes. Is it due to the 32bit sytem that I am using. Coz I heard that using the 64 bit would maximize the use of my RAM in rendering large scenes.. Any enlightenment?:confused:
Adam- I think he's talking about the OS memory map division. 32-bit Windows has a 4GB address space, which must be divided between system and application address space. The standard division is 2GB each, which becomes the limit Max can possibly get at even with swap (this is address space, not physical RAM). The /3GB switch changes it to 3GB app and 1GB system. This is sometimes not enough, and unpredictable results can occur if, for example, there is not enough system space to load the video driver. I've had better results with the /USERVA switch which allows setting a specific number in MB instead of just 3GB, E.G. /USERVA=2700 was needed on a machine in my office to let it load the Geforce driver.
Yeah your right, watching over my rendering processes in the task Manager, most of my renders is limited for just 1.5GB of RAM coz the rest is used with the application itself & other datas. Even I have a 3GB of RAM space available, I could not possibly use it all in 3DsMax. Better to switch I think for the 64-bit system. Anyway I'm just maximizing the use of my 1.6GB dual core laptop doing for such an amount of render process..
also true. ;)
