huntch3 Posted May 10, 2009 Share Posted May 10, 2009 Hi How do you render an imported dwg from cad....rendering just the lines....? Do you have to turn the entire dwg file into an editable poly in cad first?? thanks for any input Link to comment Share on other sites More sharing options...
epelj1 Posted May 10, 2009 Share Posted May 10, 2009 This is what I've done in the past.. In Autocad, print to a PDF.. then in Photoshop, save as a jpeg (or I guess a lossless format would work better) Create a plane in max with the same proportions as the pdf/jpeg and apply as a material. I'm sure there is a better way to do it, but that's my suggestion! Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted May 10, 2009 Share Posted May 10, 2009 If it's just a simple 2D file, you can import it, turn it into editable splines and select "renderable" in the modify tab. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted May 11, 2009 Share Posted May 11, 2009 This is what I've done in the past.. In Autocad, print to a PDF.. then in Photoshop, save as a jpeg (or I guess a lossless format would work better) Create a plane in max with the same proportions as the pdf/jpeg and apply as a material. I'm sure there is a better way to do it, but that's my suggestion! Or just plot to png straight from acad. You can set up page sizes just what you want (pixel count). Link to comment Share on other sites More sharing options...
