RevitGary Posted May 11, 2009 Share Posted May 11, 2009 I am new to mental ray and photometric lights. I have figured out a lot of things I am still stuck on one issue. If you are modeling an interior you light it with photometric lights. no problem. If you are modeling an exterior you use the daylight system sun and sky . Still no problems. Here is the problem if you are doing an interior with exterior light coming in from a daylight system and you have photometric lights in addition to the daylight systrm sun and sky. Do you have to do anything to the photometric lights to get them to work properly. Specifically do you have to crank up the intensity of the photometric lights to get them to work properly with a daylight system? Is there a specific formula for cranking them up and still be photometrically correct? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 11, 2009 Share Posted May 11, 2009 Yes, you will need to crank the intensity. This is where it becomes about tastes, and artistic eye in terms of how bright they are. Typically I will use a percentage multiplier until the candelas for the Photometric light are somewhere between 100,000 and 400,000, depending on the scene. Sometimes this means I need to a percentage multiplier on the IES lights of 10,000 of its original value. ...just to give you an idea of how much you might need to crank the percentage. Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 12, 2009 Share Posted May 12, 2009 check out this post, in particular page 3 http://http://www.cgarchitect.com/vb/35754-mental-ray-render-times-making-me-mental-3.html jhv Link to comment Share on other sites More sharing options...
RevitGary Posted May 12, 2009 Author Share Posted May 12, 2009 That link doesnt seem to be working Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 12, 2009 Share Posted May 12, 2009 Go to the mental ray section and search for a thread "Mental ray render times making me MENTAL " then look on Page 3 for an alternative to cranking up the multipiers. Bare in mind that this methode requires the use of Photons. http://www.cgarchitect.com/vb/35754-mental-ray-render-times-making-me-mental.html does this link work? jhv Link to comment Share on other sites More sharing options...
RevitGary Posted May 12, 2009 Author Share Posted May 12, 2009 Thats working thanks! Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 12, 2009 Share Posted May 12, 2009 Hth Jhv Link to comment Share on other sites More sharing options...
