Ricardo Eloy Posted May 11, 2009 Share Posted May 11, 2009 Alright, fellas, this is driving me crazy ... All of a sudden, 3ds max 2009 won't display any maps in the viewports when Direct3D is on. Only on OpenGL mode maps show as they should. Funny thing is that I have the exact same scene showing nicely in 3ds max 2008 also on Direct3D. Any thoughts? Link to comment Share on other sites More sharing options...
Itoosoft Posted May 11, 2009 Share Posted May 11, 2009 Max 2009 has a bug when using Multi-materials and opacity maps, perhaps this is the same problem. It's solved in Max 2010. To fix it, enable "Show Map in Viewport" in the texture, instead in the material level. The textures will be displayed in the viewport without transparencies, but correctly. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted May 12, 2009 Author Share Posted May 12, 2009 Tks for the reply, Carlos, but... No go. I already use to enable only the maps instead of the whole material because of the old VRay problem. The problem here happens regardless the rendering engine, with simple mats, just a bitmap applied to the diffuse channel and that's it. No transparencies. The objects simply show white, no matter what I do. I'm pretty sure it has something to do with Direct3D configs, but which ones? Link to comment Share on other sites More sharing options...
Karl Larsen Posted June 18, 2011 Share Posted June 18, 2011 I'd sure like to know what the answer to this one too because it just happened to me... Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted June 19, 2011 Author Share Posted June 19, 2011 To be honest, I had totally forgotten about this (more than 2 years old!). Never found the solution nor had the problem again, although I'm no longer on Max 2009... Link to comment Share on other sites More sharing options...
Karl Larsen Posted June 19, 2011 Share Posted June 19, 2011 Well I changed to Open GL to get the maps to work in viewport but it sure is strange how something like this can pop up with no known changes that I made to anything. Crazy thing is it works on my laptop in Direct3D just fine... Link to comment Share on other sites More sharing options...
Karl Larsen Posted June 19, 2011 Share Posted June 19, 2011 Updated my video card drivers and now everything works perfect even with Direct 3D! Link to comment Share on other sites More sharing options...
