bluediablito Posted May 12, 2009 Share Posted May 12, 2009 is psd manager compatible with vray? i have follow the tutorial and no good result? is there any way to make it work with vray sp2 or sp3? Link to comment Share on other sites More sharing options...
WAcky Posted May 13, 2009 Share Posted May 13, 2009 Works fine on Sp3 for me... You can't use the Vray VFB though. Link to comment Share on other sites More sharing options...
bluediablito Posted May 13, 2009 Author Share Posted May 13, 2009 hello thank you for the fast reply is there any way that you can tell me how you made it work (we have it in school it was installed during the spring break but vray was not updated and we still runing sp2) for some reason when ever i add the effect i render and i end up with a black screeen Link to comment Share on other sites More sharing options...
WAcky Posted May 13, 2009 Share Posted May 13, 2009 Go to the renderer window, Frame buffer rollout and untick "enable built in frame buffer" You will then be using the standard max frame buffer which will allow psd manager to work. Try that... Link to comment Share on other sites More sharing options...
bluediablito Posted May 13, 2009 Author Share Posted May 13, 2009 so it works perfect with vray no problems? there is no limitation the same thing i see on the tutorial i can do? i will try this tomorrow at school Link to comment Share on other sites More sharing options...
WAcky Posted May 13, 2009 Share Posted May 13, 2009 Well i use it on occasion and it works perfectly for me with Vray... Link to comment Share on other sites More sharing options...
phudge Posted May 13, 2009 Share Posted May 13, 2009 As far as I'm aware it doesnt work with xrefs, is this true? thats the only things that stopping me from buying Link to comment Share on other sites More sharing options...
WAcky Posted May 14, 2009 Share Posted May 14, 2009 Interesting...I dont use XRefs so I cant comment on that... Link to comment Share on other sites More sharing options...
gfriedman Posted November 26, 2009 Share Posted November 26, 2009 I am having trouble figuring out how to get psdmanager working with vray. I made sure that the vfb was turned off but I am getting "error creating out put file" and no rendering. There must be a setting somewhere bc a blank new file will render a psd no problem. with my file which was all ready to go and render, there seems to be an issue - I feel like it has something to do with the render elements dialog - what should I do with all my vray render elements? active? enabled? Link to comment Share on other sites More sharing options...
WAcky Posted November 26, 2009 Share Posted November 26, 2009 I just do what vray prompts me to. I think that means to have it all disabled? Not sure. Make sure you enable the Render Elements Output rollout in the psdmanager dialogue. Link to comment Share on other sites More sharing options...
neil poppleton Posted November 26, 2009 Share Posted November 26, 2009 Psd manager does not mask vray proxies, it masks the bounding box only, something to watch out for... Link to comment Share on other sites More sharing options...
WAcky Posted November 26, 2009 Share Posted November 26, 2009 Interesting. I never noticed that. I suppose you could do an extra pass using the rendermask script as a workaround. Link to comment Share on other sites More sharing options...
neil poppleton Posted November 26, 2009 Share Posted November 26, 2009 Or use the vray wirecolour pass. Nothing is ever perfect in life.......... Link to comment Share on other sites More sharing options...
WAcky Posted November 26, 2009 Share Posted November 26, 2009 I just checked a previous render of mine and psd manager has infact rendered out a heap of proxies for me. I used the material ID method. Which method of the three did you use? Link to comment Share on other sites More sharing options...
neil poppleton Posted November 26, 2009 Share Posted November 26, 2009 We use the object output layer, but will try the material ID route. Appreciate the feedback. Link to comment Share on other sites More sharing options...
neil poppleton Posted November 26, 2009 Share Posted November 26, 2009 I just checked a previous render of mine and psd manager has infact rendered out a heap of proxies for me. I used the material ID method. Which method of the three did you use? James, Could you post a snapshot of the psd panel when you get time, thanks. Link to comment Share on other sites More sharing options...
WAcky Posted November 26, 2009 Share Posted November 26, 2009 Neil, I just did a teapot test and it worked perfectly. I followed these steps exactly; 1. create a teapot and convert to proxy. 2. set its object id to 1 2. enable psd manager 3. enable G-buffer output ID output and object output 4. render. Thats it. Which versions of each are you using? I'm using max 2010 sp1 x64 vray 1.50.SP4 PDS man 2.1.0 if your versions are the same I will upload this test but a version difference is really the only thing I can put it down to. Link to comment Share on other sites More sharing options...
neil poppleton Posted November 26, 2009 Share Posted November 26, 2009 James, I have just tested with simple geometry as a proxy and it masked perfect. The problem we have is when masking very detailed proxy cars, which it cannot mask. Link to comment Share on other sites More sharing options...
WAcky Posted November 26, 2009 Share Posted November 26, 2009 Hrm. thats wierd. Might be worth posting on the psd manager forums. Oh well! Link to comment Share on other sites More sharing options...
neil poppleton Posted November 26, 2009 Share Posted November 26, 2009 Will contact cebas. Appreciate your time James. Link to comment Share on other sites More sharing options...
Trick Posted November 26, 2009 Share Posted November 26, 2009 James, When having proxied trees with opacity mapped leaves, does PSD-Manager render masks for these leaves correctly when using mat-ID ? It used to give problems on objects with thousands of opacity mapped planes over each other, like with dense trees/bushes !! Link to comment Share on other sites More sharing options...
WAcky Posted November 26, 2009 Share Posted November 26, 2009 It would appear to, yes. If you take a look at this post; the image there has a few trees, all of which are proxies with opacity mapped leaves and masked perfectly. Link to comment Share on other sites More sharing options...
Trick Posted November 27, 2009 Share Posted November 27, 2009 Sounds good !! I'm gonna take a look at it again, because it certainly would make my workflow easier. Link to comment Share on other sites More sharing options...
makrela Posted December 10, 2009 Share Posted December 10, 2009 I am having trouble figuring out how to get psdmanager working with vray. I made sure that the vfb was turned off but I am getting "error creating out put file" and no rendering. There must be a setting somewhere bc a blank new file will render a psd no problem. with my file which was all ready to go and render, there seems to be an issue - I feel like it has something to do with the render elements dialog - what should I do with all my vray render elements? active? enabled? erase the output paths for all render elements in the render elements tab. helped for me. Link to comment Share on other sites More sharing options...
makrela Posted December 10, 2009 Share Posted December 10, 2009 Please, does anyone know how to make work psd manager in batch render? thanks in advance) Link to comment Share on other sites More sharing options...
