mask on top of mask in photoshop?
Is there any way to do that? Say I have a layer with a random mask applied to it. And then I want another adjustable mask on top of that, say a gradient from top to bottom. Basically I don't want to have to destroy my original mask when I put the gradient on it.
That sort of works...I can use the bottom layer to work over the existing mask, and put my gradient on it. Then the layer above, I just keep a copy of the mask and leave it disabled in case I need it again.
I guess I could also put the layer in a group and put an additional mask over the whole thing.
Thanks for the suggestion. I guess I was just hoping there was a way to keep stacking masks on top of each other in the same layer, but these work well enough.
The second mask is a vector mask, so I don't think it has the paintability that the regular mask does. You have to edit that like a path. Stinks though, if they let you add a vector mask, why can't they just let you add another layer mask?
You can group the above layer to the lower, or you put said layer in a folder, whcih can also have a mask.
I employ both methods regularly, the second is very helpful when painting a given thing with multiple layers like veg.
If this is unclear, I can make a quick PS setup and post it as a zip, just ask.
Cheers,
Scott
  Tim Nelson said:
Yeah, William, thats what I ended up doing with mine. The only problem I saw with that was if you had adjustment layers on top of the main layer, then you start to mask that out too. But overall the group thing worked for me.
..... Calculations on the mask channels ect is the only way to get what your are describing, I believe. I use the calacualtions very frequently to combine masks, alpha channels-channels to create 'combined' masks-channels for transparencies and keying in PSD. The calcualtions-technique is closer to working in Shake, combustion for VFX though.
