Derek Forreal Posted May 13, 2009 Share Posted May 13, 2009 i'm trying to follow this tutorial - http://www.evermotion.org/index.php?unfold_exclusive=109&unfold=exclusive, but can't get the leaves on the branches as i would like. i have tried moving/rotating the pivot but i can't seem to get the stem of my leaves growing out of the branch. how can i fix this? Link to comment Share on other sites More sharing options...
Claudio Branch Posted May 13, 2009 Share Posted May 13, 2009 I believe you just need to move the Pivot Point of your leaf to the far edge of its stem and that is the position the Scatter routine will use for the rest of them. Select your object, go to the Hierarchy Tab, Affect Pivot Only, and just slide that PP over... Link to comment Share on other sites More sharing options...
Derek Forreal Posted May 13, 2009 Author Share Posted May 13, 2009 hi Claudio, thanks for the reply but i already moved the pivot! that's why i'm a bit puzzled... Link to comment Share on other sites More sharing options...
Claudio Branch Posted May 13, 2009 Share Posted May 13, 2009 Well then...perhaps it's time for Plan B. Onyx Trees. Link to comment Share on other sites More sharing options...
Matt McDonald Posted May 13, 2009 Share Posted May 13, 2009 After moving the pivot did you reset the xForm? Link to comment Share on other sites More sharing options...
Derek Forreal Posted May 14, 2009 Author Share Posted May 14, 2009 After moving the pivot did you reset the xForm? i had applied an Xform modifier and moved its centre to where i wanted but it seemed to have no effect. not quite sure what i did but playing with the modifier and the Reset XForm (on the utilities panel) did the trick pivot wise so thanks for the suggestion. now i just have to get the rotation right... Well then...perhaps it's time for Plan B. Onyx Trees. maybe. if i can't get it to work by the end of the weekend then i will look into it Link to comment Share on other sites More sharing options...
