helenistikyay Posted May 14, 2009 Share Posted May 14, 2009 need advice anything thanks Link to comment Share on other sites More sharing options...
ilovegooddesign Posted May 25, 2009 Share Posted May 25, 2009 if you use Vray you need to use vertical shift function in VRay camera or change camera view little bit to make vertical lines more parallel. and maybe use some color correction in photoshop — walls are to gray. Link to comment Share on other sites More sharing options...
Guest FlaviusC Posted May 25, 2009 Share Posted May 25, 2009 also,I think the wood is a bit too pale.Maybe a bump map and a specular map would make it look better.I agree on the color correction.maybe add a little bit of contrast to your image. Link to comment Share on other sites More sharing options...
