ravi_chawda1981 Posted May 16, 2009 Share Posted May 16, 2009 Hi, i m creating proxies, i ve followed the steps i.e., -export the mesh file(autimatically create proxies buttuon was also checked) -imort the proxies with the help of Vray Proxy my problem is the object is rendering with no material assigned, in a single material. Please help me out, Link to comment Share on other sites More sharing options...
ravi_chawda1981 Posted May 16, 2009 Author Share Posted May 16, 2009 ok fixed the problem by myself! thank you Link to comment Share on other sites More sharing options...
archigem Posted July 29, 2009 Share Posted July 29, 2009 ok fixed the problem by myself! thank you Hi I am getting the same problem, can u please help me?? I mean after placing the vray proxy in the scene it appears in just one object color, without the materials. please help Link to comment Share on other sites More sharing options...
amer abidi Posted July 29, 2009 Share Posted July 29, 2009 Proxies do not save material information. You have to save the material as a multi/sub-object material before you export the object to proxy, and then re-apply the material to the proxy after it is generated. A good tip here is to save your proxy (with the material applied) as a seperate max file, and then merge it into your scene whenever you need it instead of inserting proxy; that way, you merge the proxy WITH the material added. Link to comment Share on other sites More sharing options...
archigem Posted July 30, 2009 Share Posted July 30, 2009 Proxies do not save material information. You have to save the material as a multi/sub-object material before you export the object to proxy, and then re-apply the material to the proxy after it is generated. A good tip here is to save your proxy (with the material applied) as a seperate max file, and then merge it into your scene whenever you need it instead of inserting proxy; that way, you merge the proxy WITH the material added. Thanks Amer, Although I figured out the first method but the second tip is really useful. Thanks a lot dear. Link to comment Share on other sites More sharing options...
