chow choppe Posted May 20, 2009 Share Posted May 20, 2009 hi all please help me i was working ona photoshop file in cs4 and i hade used the save button when after 2 mins of saving the power failure made the system shut down. and when i restart and try to open the saved file, in thumbnail it shows the correct file but it opens as a black page. the file size shows fine, thumbnail shows fine but when i open it it opens a black document with just one layer. please help how can i recover my saved file with layers and all.i had saved it properly before the power went off Thanks urgent help required Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 20, 2009 Share Posted May 20, 2009 I think you should probably just start on recreating everything because this sounds like a file that can not be recovered. I would recomend saving as a copy about once an hour of the project you are working on. Something like "Project _ 01.psd, Project _ 02.psd." This way if a file corrupts int he future, you only lose a little work, rather than a lot. After all, hard drive space is cheap. Much cheaper than your hourly rate to recreate this information. Link to comment Share on other sites More sharing options...
Frosty Posted May 20, 2009 Share Posted May 20, 2009 On top of Travis' advise, which is very sound, buy a UPS. Make sure it will run at least your CPU for 10 mins, preferably the monitor as well. If you have a sever or NAS make sure they are on UPS as well AND the network switch. Link to comment Share on other sites More sharing options...
