Animate rotation
Devin Johnston
I'm trying to animate an object rotating, it's a simple enough procedure and I've done it hundreds of times. I'll select the object turn on auto key and move the time slider to where I need it, then rotate the object around the Z axis. My time line is 900 frames and I've rotated the object a total of 3600 degrees over that time, when I play it back the object only completes about 1/3 of a single rotation, no where near the 10 complete rotations I told it to make. When I go into the curve editor to see what's going on there is no information on that object even though it's clearly moving no curve data is being generated. The object was exported out of ArchiCAD in the same manor that we export all of our models and I've never had this problem before.
