markf Posted May 26, 2009 Share Posted May 26, 2009 Ive been using Max since Version 1. I'm using MAx design 2010 64 bit. I have my texture maps in a directory G\Maps\Mymaps. Under that I have additonal folders such that I have G\Maps\Mymaps\Brick and G\Maps\Mymaps\Wood and so on. In Max I used "configure user paths".In that dialog I choose External Files. I add G\Maps\Mymaps and check "Add subpaths". Al of the folders under my G\Maps\Mymaps directory are added to the list. This is how I have always set up in the past. I have a material library. Inside that library are materials with maps that reside in the above folders. I set up a material with assigned maps and save it to the library. I start a new Max scene and open the material library. I select the previously created material. In stead of the previously assigned maps I get placeholders that say, for instance, "jpeg file" where the previously assigned jpeg map should be. The materail editor doesn't seem to be recognizing my user configured paths. Am I doing something wrong? Any one else have trouble with this? TIA for any help! Link to comment Share on other sites More sharing options...
Joelp Posted May 26, 2009 Share Posted May 26, 2009 I had the same issue. Download and install the latest hotfix. Link to comment Share on other sites More sharing options...
markf Posted May 26, 2009 Author Share Posted May 26, 2009 Joel, Thanks for your reply. I have searched around on the various AutoDesk sites, Area, Subscription, Max and can't find a hotfix for Max design 2010. Can you tell me where you found the hotfix? Thanks! Link to comment Share on other sites More sharing options...
bev.lynn Posted May 26, 2009 Share Posted May 26, 2009 Mark. it's here: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=10381720 Link to comment Share on other sites More sharing options...
markf Posted May 26, 2009 Author Share Posted May 26, 2009 Got it and it fixed the problem. Thanks! (Adesk sure has allot of web sites and different areas that make it hard to find what you want) Link to comment Share on other sites More sharing options...
archigem Posted August 23, 2010 Share Posted August 23, 2010 wow this forum is really rocks..! I had the same problem and now its fixed.... ! Thanks... Link to comment Share on other sites More sharing options...
