RevitGary Posted May 27, 2009 Share Posted May 27, 2009 I dont know where they are coming from. Maybe objects I grab off the web. They are not coming from my autocad file. I have many many layers in my max file. Is there a way to get rid of ALL layers? This sure would make things a lot easier Thanks!! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 27, 2009 Share Posted May 27, 2009 I often use a script that deletes all empty layers. You could simply create a layer that contains you entourage, and then use the script\pt to delete the empty ones. I think this is the one I use, though I will have to double check when I get to the office. http://www.scriptspot.com/3ds-max/delete-empty-layer-in-the-layer-manager Link to comment Share on other sites More sharing options...
RevitGary Posted May 27, 2009 Author Share Posted May 27, 2009 OK I would like to get rid of ALL layers. If an object is on a layer make it go to "0" maybe. Link to comment Share on other sites More sharing options...
BrianKitts Posted May 27, 2009 Share Posted May 27, 2009 just select all the objects in your scene select layer "0" and click on the plus sign in the layer panel. note: that you'll have to open any groups to get their objects to move layers. Then just select all the extra layers and delete them. Link to comment Share on other sites More sharing options...
RevitGary Posted May 27, 2009 Author Share Posted May 27, 2009 WOW that was way too simple THANKS!!!! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted May 27, 2009 Share Posted May 27, 2009 OK I would like to get rid of ALL layers. If an object is on a layer make it go to "0" maybe. From a work flow standpoint I would recommend putting all of your entourage on a layer other than 0. I typically have layers called, "+ Entourage" "+ Dosch Cars" "+ Trees" "+ Evergreens" etc... These are my entourage layers. Adding the plus in front of the name keep them above layer 0 in the layer manager, therefore seperating them from the site and architectural elelments of the project. But yes, I misunderstood your original question. Link to comment Share on other sites More sharing options...
