Jez(UK) Posted June 1, 2009 Share Posted June 1, 2009 (edited) Hi, Going through the Tutorials (been out of 3ds a long time); Very simple question for all you experts out there - finding this a bit frustrating (hoping there's a better way). In 3DS Max Design 2010 - you've got 4 viewports (Top, Front, Left and Perspective). Imagine this scenario; ALT W - to view the Perspective view only (the other views were Top, Front, Left). You now want to switch to the Top view and have that as the single largest viewport viewable. If I press "T" at this point, that is indeed what I get, but if I then do a Alt-W to get back to my 4 viewport view I've now got 2 Top views (i.e. the Perspective has disappeared). This is not how I want 3DS to behave !! I want to keep Top / Left / Front / Perspective. Seems like to me that the only way to get what I want is from the single viewport view, to first do an Alt-W (to go back to a 4-viewport view) and then right click the Top view and them do the Alt-W again to view the top view in a large single viewport view - that's long winded to me. Can anyone tell me how to do this better ? Thanks, Jez Edited June 6, 2009 by Jez(UK) Only happens in Max Design 2010 Link to comment Share on other sites More sharing options...
shaneis Posted June 2, 2009 Share Posted June 2, 2009 Only admin and moderators can post to the "Tips & Techniques" board. As your query is about 3DS Max, I'd say a moderator will repost it there for you. Sorry I can't help further as I don't use Max myself. Link to comment Share on other sites More sharing options...
mattclinch Posted June 2, 2009 Share Posted June 2, 2009 just tested this and i do not get this problem. if i follow your instructions i get back my 4 original viewports with just the active viewport border around top view. Link to comment Share on other sites More sharing options...
kippu Posted June 2, 2009 Share Posted June 2, 2009 matt is right ....the same happens to me ....just the top is highlighted Link to comment Share on other sites More sharing options...
Jez(UK) Posted June 2, 2009 Author Share Posted June 2, 2009 Thanks Guys, I'm no nearer, I've taken a look at the options but nothing is staring at me that's obvious. I've dropped a line to my Dealer - hopefully he'll give me the answer. Link to comment Share on other sites More sharing options...
rmccoy Posted June 2, 2009 Share Posted June 2, 2009 The way I understand max to work. When you maximize a single viewport from the 4 views (in your case the perspective viewport) then that viewport will remain active even when you press a hotkey for a different view. By doing so it changes the view in the single viewport with out changing any others. I think this happens in Max even if you have all 4 viewports open at once. You click in a viewport and press a hot key for a different view and it will change that single viewport to something else (even giving you two top viewports for example). I think this is just how max works. I only use 1 viewport at a time so I've never really had any issues with this. I changed my hotkeys so I can access any view with a single press of a key. Link to comment Share on other sites More sharing options...
Jez(UK) Posted June 5, 2009 Author Share Posted June 5, 2009 Dealer has just gotten back to me telling me it's a bug Link to comment Share on other sites More sharing options...
Koper Posted June 6, 2009 Share Posted June 6, 2009 nope, don't seem to get this problem atm(2009sp1) but I know of it. You can reset any active viewport to a previous view(s) by hitting shift-z. and it only traces back the viewport changes for the active viewport, not all the views, and every viewport keeps track of its own changes independently. Link to comment Share on other sites More sharing options...
Jez(UK) Posted June 6, 2009 Author Share Posted June 6, 2009 I've edited my original post - it works fine in 2009, only not in 2010...... Link to comment Share on other sites More sharing options...
