tamfeldman Posted June 1, 2009 Share Posted June 1, 2009 I am not able to import sketchup files into my 3d Max 9, any suggestions? also when i try to import an AutoCAd plan or elevation i do not know how to trace the plan on 3dmax and extrude it. can anyone help me? Link to comment Share on other sites More sharing options...
BrianKitts Posted June 1, 2009 Share Posted June 1, 2009 I am not able to import sketchup files into my 3d Max 9, any suggestions? also when i try to import an AutoCAd plan or elevation i do not know how to trace the plan on 3dmax and extrude it. can anyone help me? from sketchup export a .3ds file which you will be able to import with max. Link to comment Share on other sites More sharing options...
Tim Fairbanks Posted June 5, 2009 Share Posted June 5, 2009 (edited) Importing SketchUp from AutoCAD DWG format works better - you don't get triangulation of the mesh like you get with .3ds. (i.e all mesh edges are visible with .3ds meshes). There are also fewer problems with object names getting truncated. If you DO have to use .3ds, there are some free scripts available that will help to automate clean-up of the visible triangle edges. Here's a link to one: http://www.scriptspot.com/3ds-max/quadrangulate Regarding tracing and extruding... In my experience, it's easiest and best to "trace" your splines in AutoCAD as Polylines (PLINE) on a new/separate AutoCAD layer. Draw the Polylines in a counter-clockwise direction if possible, avoid overlapping vertices, and Close the Polylines after creating your last vertex. TimF Edited June 6, 2009 by TimF Link to comment Share on other sites More sharing options...
